0300A - inspecting lifters?
Re: 0300A - inspecting lifters?
Bring it back to life very carefully. If it hasn’t run for sometime, changing the oil, removing the plugs, pressurizing the oil galleries, turning the engine over by hand for starters. I, myself also worry over stuck rings. Maybe I worry too much.
DWood
Post by DWood »
DWood wrote:
An IA I know recommends Aeroshell Plus even for Continentals as it has the additives to protect the cam and lifters.
I was told never to do this if you still have the old pull type starter as it negatively affects the clutch mechanism.
There is enough conflicting information out there that I deleted my post. Thank you.
Several “pre-buy” inspectors have advocated using a borescope thru the aft sump-drain as a method of viewing the cam lobes.
Using the cam-guard or Shell Multi-wt or “plus” oils should not have any adverse effect on the pull-starter clutch…because that clutch works on a principle of rollers becoming jammed/locked inside the clutch to impart rotation. Any difficulty with cam-guard or multi-wt oils would more likely apply to the angle-starters which rely on the friction created by a contracting-spring on a shaft ….such as applicable to the D-model O-300s.
Joe Moilanen
Post by Joe Moilanen »
GAHorn wrote:Several “pre-buy” inspectors have advocated using a borescope thru the aft sump-drain as a method of viewing the cam lobes.
Been using Cam-guard for years in my 0300D with no starter problems.
4518C
According to the Beech Talk forum at the Bonanza Society…” Aug 31, 2017 — Slipping of a starter adapter may be caused by a oil additive. ... Automotive cam guard should not be used in continental engines. …”
The rest of the conversation requires membership in that organization, but the gist is that AUTOMOTIVE CamGuard and AVIATION CamGuard are NOT the same product… so beware of using unapproved additives and lubricants in your airplane.
https://www.google.com/url?sa=t&rct=j&q ... 1TM_gwFB9c
