What tailwheel is this?
Can someone help me identify what tailwheel this is?
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Re: What tailwheel is this?
Looks like a Scott 3200.
- sfarringer
A very grungy one!mekstrand wrote:Looks like a Scott 3200.
Ragwing S/N 18073
Clean the area between the zerk and the bolt. There's often a data plate riveted there. While you're at it, clean the whole thing!
A very dirty Scott 3200 Tail wheel with a brand new tire. I will bet he landed on a dirt strip and blew the tire and it had to be replaced. Installed the new tire but did not clean it? I would have to smell the grease to be sure.
Sherlock Holms
Sherlock Holms
OK, cool, we have redefined grungy. I thought mine was grungy. My tailwheel is now "pretty clean." Thanks.
Thanks guys. Tailwheel cleaning will commence soon....
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Be careful flying that airplane after properly cleaning that tail wheel. Your center of gravity may well have changed.
She's down for annual right now. Will be getting a good bath and new shoes all round!
1952 170B
N8180A s/n 25032
N8180A s/n 25032
Is that a major or a minor alteration?blueldr wrote:Be careful flying that airplane after properly cleaning that tail wheel. Your center of gravity may well have changed.
falco,
I think it'd be a simple log book entry, but I bet the tail will come up quicker on take off.
Nippaero, after you clean it up, look at it very closely. SInce the aircraft is new to you, it is advised to look for someone elses headache.nippaero wrote:She's down for annual right now. Will be getting a good bath and new shoes all round!
52' C-170B N2713D Ser #25255
Finally got back around to posting a picture of the tailwheel. We disassembled everything, cleaned it thoroughly and rebuilt it. Also installed a new main spring from AS and a new tire and tube.
1952 170B
N8180A s/n 25032
N8180A s/n 25032
nipp, your tail-wheel cleaned up nicely.
Did you chamfer the trailing edge of the tail-wheel spring that is just above the main tail-wheel leaf spring (spring number 2), like in the below picture. Chamfering the number 2 spring helps prevent the sharp edge of the number 2 spring causing a stress riser in the main (number 1) leaf string.
