34V pretty much done
T. C. Downey
Post by T. C. Downey »
Re: 34V pretty much done
A reeallyfine looking restoration. Congratulations. Ugliest goddamn spinner I've ever seen on a C=170. A skull cap type would look a hellova lot better. (IMNSHO!)
Tell us about that exhaust.
johneeb
Post by johneeb »
Looking good Tom!
T. C. Downey
gahorn wrote:Tell us about that exhaust.
What's to tell?
simple Bartone pipes.
DaveF
Post by DaveF »
Beautiful job, Tom.
I was wondering about the approval of the exhaust...they don't look like Bartone's (which have a downward turn at the ends). Field Approval?
T. C. Downey
gahorn wrote:I was wondering about the approval of the exhaust...they don't look like Bartone's (which have a downward turn at the ends). Field Approval?
They came direct from the man with paper work for the STC.
T. C. Downey
blueldr wrote:A reeallyfine looking restoration. Congratulations. Ugliest goddamn spinner I've ever seen on a C=170. A skull cap type would look a hellova lot better. (IMNSHO!)
you find me a dome type cap for a 0-300-D, with the 6 bolt small diameter flange I'll use it.
That's good news! (The last I'd heard there was no hope for an STC. Bartone didn't have one and Benham's paperwork was incomplete.)
The skull cap dome that I had did not have anything other than a sheet metal bracket running between two prop bolts with a plate nut for a center screw through the dome.
C170U2
Post by C170U2 »
Wow, beautiful work! Enjoy flying her for a while!!
T. C. Downey
blueldr wrote:The skull cap dome that I had did not have anything other than a sheet metal bracket running between two prop bolts with a plate nut for a center screw through the dome.
That's true and it fit the big flanged 8 bolt hub of the prop. the 0-300-D has a small hub and a 6 bolt flange. the dome from a 0-300-A is too big by about 1/2" all around.
I agree with Dick's assessment. Beautiful restoration, ugly spinner. Aircraft Spruce has 5" domes. See here also.
T. C. Downey
the small domed cap is on order, Thanks for the link. Learn some thing every day.. The one I have is 6.250" if any one needs it. comes with bracket. make offer.
