New cylinder recommendations??
- Hawkeyenfo
Well, after the Nebraska to SoCal cross country trip in Nov, the C-145 developed a tick in one of the cylinders. Upon investigation, we pulled the #5 cylinder to find a flat lifter and a slightly scored cylinder with a stuck oil ring. So, we're calling a couple shops in the SoCal area tomorrow morning but I am leaning toward a new cylinder. Bummer is, low time engine (under 300 hrs).
That said, What cylinders are folks using these days. Looking at Titan and Superior. Not having any experience in this area, I'd appreciate hearing what others are using on their C-145/O-300 theses days.
Thanks, Chris.
Thanks, Chris.
Fly Navy !!!!
1941 Boeing PT-13D Stearman
1952 Cessna 170B
1960 Piper Aztec (PA23-250)
1952 Cessna 170B
Re: New cylinder recommendations??
My personal choice of those two... Superior.
No gimmicks in their processes. Good reputation and value.
J & J in Pleasanton, TX can ship overnite and they'll have the rings already end-gapped, all you have to do is pull the piston down far enough to install the new (included) wristpin, and stab 'er onto the engine.
- ghostflyer
We use Superior exclusively, never had any problems and very price competitive also . Superior reinvented the wheel ,which made their engines even better.
I use ECI standard steel, never a problem, they are the only ones that have a exhaust valve rotator that has proven to stop the exhaust valve problems.
Second vote for ECI. I put six new steel cylinders on a hundred and fifty hours ago, perfect compression and bore scope.
Good luck!
Good luck!
Overhauled my O300C engine almost 3 years ago with ECI nicad cylinders and now with almost 300 hours on them I have had no problems at all.
i am working on some hours after 1 cylinder out of 6 failed last year @ 76 hrs. Reg steel cylinders, no coatings.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
I have had very good service from a set of Superior cylinders and they would be my first choice again.
- Hawkeyenfo
Thanks for the replies everyone! I ordered a Superior cylinder from J&J (they had it in stock) and it'll be here tomorrow. Hopefully by tomorrow night, the plane will be flyin again....without all that noise in front!
On a better note, flew the Stearman this morning after ordering the cylinder and flew in a FA-18F Hornet this afternoon! Nothing like hittin both sides of aviation history in one day
Fly Navy !!!!
1952 Cessna 170B
1952 Cessna 170B
You, are one lucky guy!! that's me, green with envy!!
- Hawkeyenfo
Thankful each and every day!
Fly Navy !!!!
1952 Cessna 170B
1952 Cessna 170B
