'98C Gets a New Interior
Re: '98C Gets a New Interior
In between bouts of working on the windshield we got a bit more paint removal done on the interior and its many parts. Of course I had some EXCELLENT help!
While we've pretty much settled on interior materials and colors, I'm still thinking about doing some kind of unique yet attractive piecing and stitching for it. I took a photo of the door and have been playing with it in Paint (a poor-man's PhotoShop that comes in the Accessories folder on all Windows computers). It was a bit tedious to get a blank area cleaned out of the photo, but then it's fairly straight forward to play with ideas. I'm sure PhotoShop would be even easier, as Bruce has shown us.
The brown we've chosen is darker and more neutral than what shows here, but I'm really just looking at patterns. I'm also thinking about incorporating the Cessna 170 logo, and/or the stylized bird from the original pait scheme into the stitching.
- W.J.Langholz
I like the bottom one, not as busy....can you make the lines go the other way?
May there always be and Angel flying with you.
1942 Stearman 450
1946 Super Champ 7AC
1942 Stearman 450
I agree that the wider stitching looks better (to me) and slanting it the opposite way would look good too, but either would be nice. Have you given any thought to adding arm rests? I added them to Ole Pokey way back in the 90's and wouldn't want to be without them. They sure help on those long (and short) trips. Mine may have come from and automobile. An FBO had them in a box of things I bought from him and I painted them myself (the first time) and had the upholstry guy cover them in the same material as the door panels. It was easy to rivet in some aluminum supports in each door to anchor the rests. If you should decide to install them I suggest deciding exactly where you wish them to be for your comfort and most likely you will want the forward end to be a bit higher than the rear as opposed to having them level with the window openings. Putting a bit of angle on them makes them even more comfortable. Of course if you are wanting to stay orginal or sort of orginal they wouldn't work.
I mfr'd armrests for my Aeronca by taking flat sheet metal 8 inches long and, using a brake, bending it into an
Isosceles triangle (end view) and covering it with 1/4" foam and the same fabric as the sidewalls. Really made
the cabin more comfortable. It can be attached by pop rivets or screws.
How 'bout these?W.J.Langholz wrote:Miles
I did think about armrests, but I'm trying to avoid the "while-I'm-at-its", and will put that off for a future project, if ever. And actually, I'm fairly comfortable with my forearms on my thighs and fingertips on the bottom corners of the yoke.170C wrote:...Have you given any thought to adding arm rests? ...
BL is BACK. Yahooo.
Miles I would stick to the vertical stitching. Slanted either way reminds me of something you might find in a Mooney or a dreaded plastic airplane today.
I'd also opt out of the giant 170. I kind of like the bird logo with just the small 170 but I'd probably opt for just the bird and make it large enough that you might not recognize it as the bird but rather a design element.
Ol'Gar feels similarly. He's also comfortable with his knuckles draggin' the ground.cessna170bdriver wrote:I did think about armrests, but I'm trying to avoid the "while-I'm-at-its", and will put that off for a future project, if ever. And actually, I'm fairly comfortable with my forearms on my thighs and fingertips on the bottom corners of the yoke.170C wrote:...Have you given any thought to adding arm rests? ...
On a more serious vein... have you considered what Cessna originally did for accents? and have you thought about horizontal pleats? I think that may make the aircraft appear more roomy for some reason.
I think any woman would agree with you on the horizontal pleats (or stripes) having a more "roomy" appearancegahorn wrote: and have you thought about horizontal pleats? I think that may make the aircraft appear more roomy for some reason.
Del Lehmann
Mena, Arkansas
Mena, Arkansas
Point me toward some photos or drawings and I'll take a look, although I'm looking for "original" in the sense of somewhat unique or creative. (I know, I know, not something you'd expect out of me... )gahorn wrote:... have you considered what Cessna originally did for accents?...
Not bad...gahorn wrote:...have you thought about horizontal pleats? I think that may make the aircraft appear more roomy for some reason. ...
Suggestion: Make the lower pleat wider (get rid of that last 1" seam down there)...and of vinyl or leather (same color as upper) ...for scuff protection from shoes.
Or just make it carpet like this one. (Hmmm... back to the vertical pleats )gahorn wrote:Suggestion: Make the lower pleat wider (get rid of that last 1" seam down there)...and of vinyl or leather (same color as upper) ...for scuff protection from shoes.
