Exhaust style
Exhaust style
My 170A (O-300A) currently has the 'stock' exhaust system, where the stacks come through holes in the cowling. I'd love to look into the type of exhaust system pictured below, and I'm wondering how many of you have it, how it's put together (what kind of bracing is needed, where you got/how you made the system etc.)
Also, any input on the benefits/drawbacks of each system would be very helpful!
-Trevor Meeks
Filmmaker http://www.meeksdigitalstudios.com
Photographer http://www.meeksdigital.com
1950 Cessna 170A N5LP, Horton STOL, 180 Gear
Re: Exhaust style
Trevor,
That is either the Benham or Bartone system. They are two slightly different systems that accomplish the same thing. Most people don't know the difference in the two systems but there is and only Behnam or Bartone could probably tell you what it is. In addition to that is seems most of the installed systems regardless of who's it is seem to have some customization done by the installer.
John D. Benham is one of the two founders of the TIC170A. He sells the parts and STC he owns for his system as far as I know. Pat Bartone another member of the TIC170A sells parts for his system but will not sell his STC as of a few years ago. Both gentleman can be reached through their contact info in the membership directory.
There are many people who have these systems. In fact depending on the convention attended there may have been more of these systems than stock represented. Mile Bowen is one of the last I know who installed this system so maybe he'll chime in.
As for benefits some say you will get speed increase but that is questionable. Others say the system is quitter than stock in the cockpit but who knows. Others site the ease that the cowl can be removed and reinstalled with the systems. One thing for sure you won't get exhaust stains on your cowl anymore. Instead they will be on the belly.
Re: Exhaust style
Those look like the Bartone pipes (due to the downward turn at their lower ends). The Benham pipes are straight all the way to the lower ends. Also, the original Benham pipes are suspended from the engine mount, while the Bartones are suspended from the firewall via hangers. (Both STC's are commonly violated in that regard, however.)
Re: Exhaust style
Trevor,
What my Bartone exhaust extensions look like
I purchased the exhaust extensions in 2003 and they were installed via 337 Field Approval. Pat does not sell or furnish a STC with purchase of the exhaust extensions. Pat did furnish, as I recall, several different illustrations on how to attach the pipes. The one I used appears to be what others are also using. Todate they are working great with no problems.
Jim Wildharber, Kennesaw, GA
Re: Exhaust style
Here are some pictures of my Benham exhaust inistall on my 1955 B-model. (per the STC). I actually like the look of the Bartone pipes better but they required field approval, whereas the Behnam's have an STC. I took the path of least resistance.
Re: Exhaust style
I saw no speed increase. With "down and welded" landing gear, wing struts, and a stock engine, I don't think there's a lot that can be practically done to make a 170 significantly faster. I can't really say the cockpit is any quieter, but at idle the it has a "bigger", throatier (but not louder) sound than with stock pipes. In cruise I can't tell a whole lot of difference.N9149A wrote:As for benefits some say you will get speed increase but that is questionable. Others say the system is quitter than stock in the cockpit but who knows. Others site the ease that the cowl can be removed and reinstalled with the systems. One thing for sure you won't get exhaust stains on your cowl anymore. Instead they will be on the belly.
I did it mainly for (1)the look, (2)to keep the exhaust stains off the cowl, and (3)to make the lower cowling easier to remove/install, in that order.
(1)As far as improving the look, that is a subjective thing, and you have to make up your own mind. I personally think not having the pipes through cowl is an improvement.
(2)These pipes obviously enable keeping the cowl cleaner, and DO NOT add stains to the belly.
(3)As far as making removal/installation of the lower cowl easier, it is definitely easier to remove... a bit too easy perhaps if working solo, as the old pipes would "hold onto" the cowl even after all the screws were out. Now, after taking out the last screw on either side, I have to make sure the cowl is supported while I walk around to take out the last screw on the other side. Solo installation is somewhat more difficult for the same reason. Having a helper makes it much easier.
Re: Exhaust style
[img]
HI DAIRYDR HERE I ALSO WOULD LIKE TO INTALL THE BARTONE SYSTEM ON MY DADS 53 170 B I LOOKED THROUGH THE MEMBER DIRECTORY BUT DID NOT SEE A MEMBER BARTONE ,CAN U HELP ME TO CONTACT MR BARTONE
[/img]
[/img]
cessna170bdriver wrote:I saw no speed increase. With "down and welded" landing gear, wing struts, and a stock engine, I don't think there's a lot that can be practically done to make a 170 significantly faster. I can't really say the cockpit is any quieter, but at idle the it has a "bigger", throatier (but not louder) sound than with stock pipes. In cruise I can't tell a whole lot of difference.N9149A wrote:As for benefits some say you will get speed increase but that is questionable. Others say the system is quitter than stock in the cockpit but who knows. Others site the ease that the cowl can be removed and reinstalled with the systems. One thing for sure you won't get exhaust stains on your cowl anymore. Instead they will be on the belly.
Re: Exhaust style
Look in the state of Connecticut. Page 18 (at least the electronic version)DAIRYdr wrote:[img]
HI DAIRYDR HERE I ALSO WOULD LIKE TO INTALL THE BARTONE SYSTEM ON MY DADS 53 170 B I LOOKED THROUGH THE MEMBER DIRECTORY BUT DID NOT SEE A MEMBER BARTONE ,CAN U HELP ME TO CONTACT MR BARTONE]
Re: Exhaust style
Here are some pictures of the Bartone exhaust.
